[13.08.2012 13:06:23] Application error (545, 540, 275, 16): "List index out of bounds (1)"
[13.08.2012 13:06:57] Application error (545, 540, 305, 0): "Access violation at address 0061F35B in module 'CommFort.exe'. Read of address 00000000"
[13.08.2012 13:08:52] Module 1 (23) is activated
[13.08.2012 13:08:53] Module 1 (22) is activated
[13.08.2012 13:09:14] Module 17 (0) is activated
вылетело в момент приема файлов. бесконечно шло определение скорости. клиенты в одном сегменте.
Передача файлов
Re: Передача файлов
[13.08.2012 13:26:59] Application error (545, 540, 333, 16): "Access violation at address 00621648 in module 'CommFort.exe'. Read of address FFFFFFCF"
[13.08.2012 13:26:59] Application error (545, 540, 257, 0): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:26:59] Application error (545, 540, 333, 16): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:26:59] Application error (545, 540, 255, 0): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:02] Application error (545, 540, 333, 15): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:02] Application error (545, 540, 255, 0): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:02] Application error (545, 540, 333, 16): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:03] Application error (545, 540, 333, 16): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:03] Application error (545, 540, 255, 0): "Access violation at address 00000000. Read of address 00000000"
[13.08.2012 13:27:03] Application error (545, 540, 333, 15): "Access violation at address 00000000. Read of address 00000000"
отмена передачи и повторный запуск. опять не прошло. еще раз отмена и на третий раз передалось.
Re: Передача файлов
плагинов ни каких не стоит
Re: Передача файлов
Используется бета-версия клиента. Необходимо обновление до финальной.
Сбой в памяти произошел капитальный, даже данные касающиеся иконки в трее были повреждены. В данном случае без перезапуска программы корректная ее работа невозможна.
Что вызвало сбой - необходимо выяснить. Но выяснить удастся только если проблема повторится. Просьба пользователю обратиться еще раз со всеми наблюдениями если проблема повторится (дополнительные наблюдения необходимы такого рода: сворачивалась ли программа перед сбоем в панель задач, находился ли компьютер в ждущем или спящем режиме перед проявлением проблемы).
