Access violation at address 005944A7 in
svv525
Re: Access violation at address 005944A7 in
Сообщение svv525 »
[14.11.2010 11:57:47] Application error (503, 500, 173, 141): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:57:48] Application error (503, 500, 173, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:57:48] Application error (503, 500, 255, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:58:15] Application error (503, 500, 243, 125): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:58:15] Application error (503, 500, 255, 31): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:58:15] Application error (503, 500, 173, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 11:58:15] Application error (503, 500, 255, 0): "Access violation at address 00000000. Read of address 00000000"
Появилось после обновления с версии 4.41 до 5.0.3.2
Плагинов и доп. скинов нет.
svv525
Сообщение svv525 »
И вообще, если нельзя устранить ошибку, можно как нибудь удалить канал события?) Или сделать так что бы сообщение об этой ошибке не показывалось?
svv525
Сообщение svv525 »
хы, поставил крейзи плагин и ошибка исчезла)))
[14.11.2010 14:34:25] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:26] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:27] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:28] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:29] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:30] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:31] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:32] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:33] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:34] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:35] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:37] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
[14.11.2010 14:34:38] Application error (503, 503, 178, 0): "Access violation at address 004C4F77 in module 'CommFort.exe'. Read of address 55869B1C"
и пошло так далее
[14.11.2010 16:22:38] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:39] Application error (503, 503, 349, 16): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:40] Application error (503, 503, 126, 15): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:40] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:43] Application error (503, 503, 277, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:44] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:44] Application error (503, 503, 255, 16): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:22:44] Application error (503, 503, 349, 15): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:23:07] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:23:07] Application error (503, 503, 126, 16): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:23:09] Application error (503, 503, 368, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:23:09] Application error (503, 503, 126, 16): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:23:09] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
[14.11.2010 16:24:01] Application error (503, 503, 349, 0): "Access violation at address 00000000. Read of address 00000000"
К сожалению сегодня то же пользователь написал об ошибке ...
(94.21 КБ) 119 скачиваний
viktor6
Сообщение viktor6 »
Была и у меня такаяже ошибка после не удачного обновления клиента но ошибки ушли когда удалил и заново поставил клиент
Может быть несовместимость с вин7 х86 ?
В случаях sasha и Chudik виноват однозначно плагин. Обновите CrazyPlugin и проблема исчезнет.
В случае svv525 имеет место другая ошибка. Подозреваем что вот эта. К сожалению, пока ее найти не удается, необходимы максимально подробнрые наблюдения.
Chudik писал(а):Может быть несовместимость с вин7 х86 ?
У программы-чата не может. У плагинов может быть несовместимость с Windows UAC (если они хранят временные файлы в папке с установленным плагином).
[15.11.2010 22:40:59] Application error (503, 503, 275, 46): "List index out of bounds (1)"
[15.11.2010 22:46:00] Прием файлов "2002-01-15_215101.jpg, 2010-01-15_220304.jpg..." (3 MB) от пользователя ALEXshooter завершен
[15.11.2010 22:50:04] Application error (503, 503, 305, 2047): "Access violation at address 005F01BF in module 'CommFort.exe'. Read of address 00000000"
[15.11.2010 22:50:16] Module 1 (13) is activated
[15.11.2010 22:50:22] Module 1 (13) is activated
[15.11.2010 22:50:57] Module 1 (13) is activated
[15.11.2010 22:51:30] Module 1 (13) is activated
[15.11.2010 22:51:41] Module 1 (13) is activated
[15.11.2010 22:52:13] Module 1 (13) is activated
[15.11.2010 22:52:40] Module 1 (13) is activated
[15.11.2010 22:52:54] Module 1 (13) is activated
[15.11.2010 22:53:00] Module 1 (13) is activated
[15.11.2010 22:53:22] Module 1 (13) is activated
[15.11.2010 22:53:54] Module 1 (13) is activated
[15.11.2010 22:54:10] Module 1 (13) is activated
[15.11.2010 22:54:21] Module 1 (13) is activated
[15.11.2010 22:54:41] Module 1 (13) is activated
[15.11.2010 22:55:39] Module 1 (13) is activated
[15.11.2010 22:57:04] Module 1 (13) is activated
клиент 5.03а
Cilvay
Сообщение Cilvay »
Сразу видно, чат комфорт писался в C++ билдере
wizard50 писал(а):[15.11.2010 22:40:59] Application error (503, 503, 275, 46): "List index out of bounds (1)"
клиент 5.03а
Данная проблема проявилась единожды? Если нет, то были бы полезны максимально подробные наблюдения.
FiLE95
Сообщение FiLE95 »
У меня тоже возникла проблема:
[04.12.2010 13:36:58] Module 1 (54) is activated
Windows 7
версия 503a
Переустановка не пологла. Ошибки возникают при: смене статуса, публикации картинок и смайлов. Публикация статуса, картинок и смайлов невозможна. Смайлы не загружаются.
@serg@
Сообщение @serg@ »
FiLE95 писал(а):У меня тоже возникла проблема:
Windows 7
версия 503a
Обновись до последней версии, в ней исправлено множество ошибок, по результатам отпишись.
